Williams":v30zdz3v said:Did you get this sorted Matt..?
Peugeot use the same coil on their v6 iirc. 406, 407 etc
Snails":8w1nd0v7 said:Williams":8w1nd0v7 said:Did you get this sorted Matt..?
Still on the side of the road. Citroën are open today, does anybody know the part number they use?
I was on my way to the 5th Annual Fish and Chip run to Aldeburgh with Piston heads as well
Edit. Citroën parts are closed, only open for test drives.
CITROËN C5 01- Valeo
V6 2HOT":26h9jno6 said:I have spares at home but I am working today otherwise I could have run them up to you. I didnt know there was a PH run on today otherwise I would have gone!! Aldeburgh is one place I have always wanted to visit and never got around to it. And I have heard about their reputation for fish and chips :bow:
I keep a whole bank of coils as spares not just one. I once had two coils go so having three came in handy.
Oh and sometimes the coils from gsf have part no. 925PC0000 on the box as the code did change over time. Same part just one no. change.
Snails":nbgfehjb said:Their parts department is closed on Sunday. Here is to hoping Mr. RAC has one. Ha.
Matt":28b292gu said:Where's the A12?
Matt":sxldd06a said:Bit far - was gonna pop over if closer with a coil pal.
Matt":ptpakyq0 said:185 is a misfire on cyclinder 5
113 misfire cylinder 3
112. Is fire cylinder 2
114 misfire cylinder 4
Sometimes multiple coils can give up at once which is most likey what is causing the fault codes to come up.
