Hello my name is Javier, i am from México, i bought the car 3 months ago, I almost don´t used the car, the car has only 9500 km. In México Renault did not sold this car, so all the cars has to be imported from europe.
We're here to give you any advice (or help sourcing parts) should you need it.
My only concern for you would be finding a technical expert for the cambelt service (or any other 'engine out' procedures) in Mexico.
Otherwise - enjoy! I bet it gets a lot of attention! : )
The first one has the car for 10 years, the second just a couple of months and then he sold it to me.
The only changes that the first owner make to the car are the exhaust, the air filter and the calipers on yellow color, because the carbon fiber was an sticker an i removed.
The exhaust is Magnaflow, it´s too loud for a daily drive.
No, I don't think that's true.
The parts needed will be relatively easy to source though. The problem is the engine removal. This is taken from another section of this forum - to help consider the issue...
fred":2ekam8sr said:
i doubt you'd be able to time the engine up correctly with it still in, i'd be VERY surprised if the timing was cock on! It takes us 4hours to remove the engine/box completley, but we have the special Renault cradle for the engine/box which makes things MUCH easier!
Its a bit of a pratt to time the engine up AND get the belt tension correct with it OUT of the car, sod even attempting it with the lump still in the car!
