Following from my previous post (Mk2 geo settings)
I’ve just picked up my Vee from the stealers after being forced to make them do the geometry again which should have been done correctly in the flipping first place!
Anyway I now have a vee that handles how it should do and two brand new PS2’s (obviously all FOC).
When set-up correctly the Vee handles like a dream, its like a totally different car!! :shock:
After close inspection of the print out I am now running +30 (spot on +15/+15 r/l) on the front toe and +0.44 (spot +0.22 rl) on the rear
Camber wise I’m now running:
-1.33 (left rear) and -1.55 (right rear)
-1.16 (left front) and -1.02 (right front)
Apparently this is to Renault’s specs (although the front left camber is technically outside of renault tolerances by 0.11 and the rear right camber is out by 0.05)
I’m not complaining about the front toe settings as it now means the fronts shouldn’t wear as much on the inner edges anymore (Harry also recommends this setting and is also listed on the Biers download)
Just for the record it appears that different information sources all contradict each other when it comes to recommended geometry settings:
French Renault technical manual V’s English Renault technical Manual (taken from alpine web site) V’s Renault UK’s figures V’s Biers blue tooth alignment download - the question is who to believe.... anyway although the left front and rear right camber settings are technically out of Renault tolerance levels they are so minor am not too worried about this as I doubt any human could tell the difference...?
All in all I have learnt two lessons from this whole episode:
Never take your Vee to a main dealer and always double check the work agreed on your sales invoice :bubble:
