right my car has them single nut hubs and was wondering if the v6 hubs are the same as a normal clio.incase i ever want to change back to standard wheels etc and does the mk2 wheels fit the mk1 ok, cheers
I can't believe the owner changed the hubs! Are you sure there's not some clever normal hub on the back single nut on the front type converter type thing used?
Anyhow, Vee hubs are 5 stud vs. 4 stud on a normal Clio, so you can't use normal Clio hubs if you need to replace them.
Regarding the Mk1/Mk2 question ... I reckon offsets are different but must admit I don't know the exact ins-and-outs but others do.
