Passkeys can be managed for your account under Account > Password and security. To kick the process off you simply click "Add passkey" which, in supported browsers, will invoke some sort of interface, usually served by your browser, device, or password manager.
It's that easy! From that point forward, not only will you be able to use your passkey for logging in, it also enables any of your current or future passkeys to be used as two-factor authentication.
It's just as easy using a passkey as it is to add one. Let's take a look at the login flow with the passkey I just created:
No need to enter your password. No need to even enter your username! Just tap "Log in using: Passkey" and follow your device's prompts and you'll be logged in!
Passwordless login
