How to clean behind the badges ?
looch
Hello all
Any tips on cleaning the build up of dirt and grime behind the renaultsport, clio and v6 badges on the boot ?
[smilie=thanks.gif]
A cut down half inch paint brush does the trick matey ;)
You can also use little detailing sticks, there like a little foam pad on a plastic stick if you havent seen them,
Sure Dawsn will be on soon as she told me off at Kimbolton for leaving wax on my badges! (not a euphomism by the way) :)
Gave mine a wipe the other day. :)
If you insist on taking them off, use tim's advice, a little heat, but then soak in warm water and lever off using dental floss. Voila.
