Hi all, I have to do the head gasket on my 21 Turbo, its years since I did a head gasket so before I start can some one please tell me....
1: When I leave the head into be skimmed should I remove the valves?
2: Also when I remove the head bolts does the rockers lift away from the head?
3: When I remove the distributor does it only fit back in the one way or is the drive end of it on a teeth drive?
4: When lifting the head away from the block should I worry about the liners coming with the head?
5: Can anyone recommmend where I can get a good quality head gasket set please.
I had a search through old forum's but I couldn't find a discription for replacing a head gasket, so if anyone has any advice it would be great!
Thanks.
YEAH!
Thanks.
YEAH!
