Grand scenic suitable donor for 225 lump?
Duncan Grier
So does anyone know if the renault scenic grand version shares the same chassis / underpinning of the megane 225
I know they did a 2.0 t lesser version
Well you see where this could go as a more interesting daily and need for the space so a consideration versus what comes out the tin
Any advice welcomed to what parts are interchangeable etc etc
Cheers
DG
Yes sure detunes one runs higher compression and tiny Tb. Not sure of cams and other internal differences
I was thinking a not 2.0t base but maybe a even easier swap. Not looking for anything crazy
Lsd and 300bhp along with mild chassis upgrades and brakes.....and tow bar
If it gets to expensive it would make more sense to go zafira vxr or 2.5t smax route
Just like to be different.......because I'm special lol
DG
Thanks Andy
I have never looked at either car so far from best placed to say. Hence asking you lot ;)
If box etc is different and loom most the way there then it seems to make more sense to get soec of car on whatever 1.6 and drop it in :)
Make an exhaust and parts bin for i/c etc
DG
Apparantly the crank is different to a 225 lump too. Mine had an auto box on it so not sure if they even share a similar gearbox. I dont think it shares the same suspension setup as a meg, more a conventional mcpherson strut compared to the dual axis setup of the megane sport.
Cheers brigsy
Starting to look like poss not the best of both worlds quick conversion
Did they do an rx4 version of the newer shape 2004-8 type range?
Might as well Quattro and s3 dsg the thing lol
Dam the need for mpv ness ;)
Has to seat 5 full seats but having 7 a big help
Vauxhall the obvious choice but just not a massive fan of the inside layout compared to the other 7 seater options
Sure I will sort something
Cheers
