Using second and third gear for about an hour on the fantastic roads around the Lakes has lunched third gear in my gearbox.
Crunching and refusing to engage third in all but the gentlest of downchanges. Changing up is ok if it's done slowly. Once engaged the whirring is much louder than normal - also louder in fourth strangely - and I can physically push the gear lever forward once third gear is engaged where I can't in every other gear. Third gear works though, car accelerates as normal.
So, I assume third gear synchro is fooked. Fourth affected as well hence the louder than normal whirring? As I see it my two options are: full rebuild for peace of mind or source a ph2 box from somewhere. I won't be driving the car much till next spring/summer and am avoiding third gear so will look to get something sorted when cambelts due next spring.
Questions: from the above does it sound like a synchro issue? How much to recondition current box? How much is a ph2 box?
[smilie=thanks.gif]
[smilie=thanks.gif]
