Gearbox shaft tube needed!!!
A
ashcam1221
Hi guys well went to get my ph1 moted and notticed oil leaking from the bellhousing. Took the gearbox out as the clutch was sliping turns out gearbox oil is coming out of the shaft on to the clutch. After taking the bellhousing off the gearbox the tube with the O ring on it has snapped!
So has anybody got one laying about in there shed? Havent even tryed Renault's yet dont even know if they are avaliable?
I also need the the plastic end cap thing that go's in the end of the tube to keep the shaft centered?
Cheers guys
Ash
Hi
you need to speek to Chris cole of mach 1 transmission via Davel485 or Kevin at GTO engineering, one of them will have what you need
Andy
