fuse layout for under bonnet and boot please
Hi
Yes what fuses protects what and its correct ampage and its postion in the holder as the manual only does the interior fuses
Cheers
Steve
Under bonnet fuse box and relays.
I hope these are what you're after Steve?
Kind regards, Steve.
P.S. I'll do the boot ones in a bit.
....and here's the boot ones:
Yet again, I assume these are what you require Steve.
Note to self - next time I offer my services to someone on the forum, think about my own ability to achive said goal! (i'm fooking soaked!).
Regards, Steve.
Thanks Steve
No need to rush the pictures though like that its only been 3.5 years so far no need to get wet for me [smilie=thanks.gif] , that said it now runs again [smilie=icon_cheers.gif]
Does anybody know what fues does what though ?
Cheers
Steve
Hi steve, had a similar dilemma with a fuel pump fuse and relay, ie could not find which one was which, as you know i do have a damaged spare car so i did my diagnosis on the spare to save stripping the good one, all went very well untill i found the french are'nt too careful of putting the fuses in the same space on two seperate cars, they are in the same general area but dont take for granted if someone suggests bottom row second in etc, they are not all the same!
a good bit of kit is called a power probe from the snapon man, this device is powered from the vehicle and shows voltage at probed points in loom, it also allows you to inject a pos or neg pulse to id different circuits, i bought one and it saved shedloads of time, not cheap though, pm me for more info, spike.
