Front Pads
stevewinstone
Hi all,
I think that my Vee (ph2) may need new front pads soon as they are starting to feel a bit juddery. Question is what pads should I replace them with? I believe they are currently the standard ones with standard discs.
Advice / ideas much appreciated.
Many thanks,
Steve.
A variety to chose from. Proper OE ones from Renault are hugely expensive. Some people go with cheap Mintex ones which fit well on the front (but on the rear are tiny bit big). A popular choice is to go with slightly sportier pads from EBC ... I run red stuff pads which work well and are a good compromise pad, others run more "fast road" yellow stuff pads. Can't remember what I paid from my red stuff pads, but they were pretty reasonable.
Look in the Members' Area for a discount from a brake pad supplier.
This should help
Been doing some research on brake pads, in the Renault manual its says min pad thickness is 9 mm but on the AP product info it says 2.5 mm looks like a good way of Renault fitting new brake pads well in advance of when there needed according to AP.
AP part numbers for calipers are CP6605-80S TWR and CP6605-9SO TWR
Clio front pads are the same as
Morgan Aero 8 4.4 2000 on
Noble M12 3.0
TVR, Cerbra, T350, Tuscan etc
Seat Cupra Sport (model ?)
PRICES AND PART NUMBERS FRONT PADS
OMP OT8104 road and sport £55 EBAY
Mintex xtreme MDB2207X £51.06 from A to Z motorist centre
EBC Redsuff DP3036C £74.65 inc
Ferodo DS2500 FRP3083H £82.60 inc
Mintex M1144 MDB2207M1144 £98.20
from Camskill performance all plus post £8
Padgid 20345 about £190 !
Ferodo DS3000 FRP3083
Brake pad retaining pin and wear plate kit available from SEAT, but are AP parts, part no 6LL698295 @ around £60, but dont know what wear plates are ! Do now,they are the 4 stainless plates screwed to the caliper at each end of the pads, should not need replacing unless damaged.
REAR PADS
Mintex MDB1526
Rear pads are also for Citroen XM all models FRONT FITMENT
These retaining pins can be very rusty after a long period, I had to use a wire brush on a drill and tap them out a bit, then rotate them bit by bit and clean them all up before they would tap out though the other side of cailper, I have cleaned and painted them but there still not great, but for the cost of £1.77 each, I have brought some new ones.
You should think about these if you are looking to do the job in one go, I have read on the Cupra forum that some people have wrecked their pins getting them out.
2 sets of 4 x CP6600-109 pad pins are in stock at
For B G Developments Ltd
Unit 9 West Court
Buntsford Park Road
Bromsgrove
B60 3DX
Tel: 01527 873716
Fax: 01527 575403
E-mail: [email protected]
I had Galfer 1065 Pads fitted to my front. No idea who supplied them to the specialist I used. I seem to recall they very quite expensive though.
