just to confirm Matt, its a 10mm hex tool, doesnt need to have a ratchet tool, a solid bar will do it. Best to clean out inside the bolt head first so the tool fits in all all the way. (no jokes please!) I had to use an electric impact wrench on mine years ago as they were so tight and there was no way to get decent leverage in the available space.Matt":1tk9dnrm said:Can confirm its a hex 10mm ratchet tool to remove Caliper bolts and a t40 for discs.
Just need to get em off now!
eastlmark":2r4zdsz9 said:just to confirm Matt, its a 10mm hex tool, doesnt need to have a ratchet tool, a solid bar will do it. Best to clean out inside the bolt head first so the tool fits in all all the way. (no jokes please!) I had to use an electric impact wrench on mine years ago as they were so tight and there was no way to get decent leverage in the available space.Matt":2r4zdsz9 said:Can confirm its a hex 10mm ratchet tool to remove Caliper bolts and a t40 for discs.
mossyv6":agmft2fd said:What you upto Matt, new discs?
