A
Anonymous
It's just a small thing, but I experimented a bit with the front allignment, since I was quite p#ssed off by the fact that the front tires have excessive wear on the inside.
So after a 10000miles test I found that a negative toe of -30 minutes should be +30 minutes.
It really changes the wear much more regular, still a bit more on the inside but not excessive.
I couldn't find any negative effects from the mods, just that the backend steps out a bit more with an advance warning.
But this ain't a problem for me, I kinda like it.
I must add, that I also have a rear torsionbar, and stiffened front bushings.
Up to now 150000km on the speedo :shock:
