A
Anonymous
Does anywhere make forged pistons and rods for the V6?? I know places to custom pistons and rods so its not the end of the worlds if no-one does them.
Even Billet rods would do.
Bucky":2cxnd6kb said:Does anywhere make forged pistons and rods for the V6?? I know places to custom pistons and rods so its not the end of the worlds if no-one does them.
Mike T":1ey0ssoa said:Not really.
I've run 1.2 bar on standard rods and low comp 8.2 HKS pistons.
Not revving high on Turbos so no need for crank unless over 500bhp
What boost you targetting to run - target bhp/torque?
Twin Turbo or single?
What ECU/Injector size.
decent boost control and engine management can ensure the standard parts are well up to most things.
Mike T":392k8h4k said:With the under cover or not temps you will be running BB turbos eventually, its to hot for non BB - coolings a real bitch - even with a charger I get oil temps of up to 130 degrees even with an external oil cooler.
Contact Steve at SWR Motorsport in Swindon for M6 or 800 - use my name.
Gearbox conversion is about £12k including shafts/linkages etc etc but the Motec flat shifts and rev matches on downshifts so the clutch is not needed.
The standard clutch is shite so you'll need a trophy flywheel and twin plate clutch.
Have you thought the drive train through - it won't take turbos - it can barely take the standard engine, its a van gearbox and non lsd diff.
Also the fuel system won't cope - you need a swirl pot - twin in tank pumps and a Bosch 044 fuel pump. The fuel rail is plastic and needs replacing with a billet item and a rising rate regulator plumbed in - this is all best in aeroquip feeding from a custom aluminium toplate on the fuel tank.
Chargecooler rad at the front is installed by removing aircon and replacing the aircon rad with a second renault v6 rad plumbed to feed the chargecooler
Jabsco chargecooler water pump is best switched at 25 degrees AIT by the Motec for long life - my inlet temps don't go over 35degrees.
Air to air intercooling is a nightmare and doesn't work - best chargecooler is a PWR item from Australia
