Haz
i've owned the car a while now and kept up with the general maintenance it needs but after a few old hoses starting to split and the thermostat sticking causing temps to rise which has been sorted but now noticed it leaking from the front, i'm guessin the waterpump. also the rad is looking rather shabby. i've been down on boost from the usual 16psi to about 9psi, i've replaced the flexi pipe a while ago and is fine, submerged the ic's and they're fine. no leaks on the turbo or manifolds either. poss the actuator but yet to check as just been parked up since the leak as been usin the works van anyway, sooo, i've decided that as its ma daily driver i'm tryin to withhold from painting it so as i've a few jobs to do i'm thinking of going all out. i've read as much as i can on here from the last year or 2 so i'm hoping there's a few of you still trying to improve performance etc. i have had a look at tony's quadra and had a chat a while ago, and looked/read what i can thru google etc and here's what i'm thinkin. . .
it looks nearly original under the bonnet, not mint, so trying to not go ott with painting etc, just clean, it weeps oil so a full gasket set is on the cards, and looking for the thickest head gasket availiable, any suggestions? also what should the height of the head be? any preference on cambelt kits?
since it'll be in bits, unless its worn i dont plan to change much, but want to up the oil pressure on the pump. are the group buy of springs still happening? are there any other bits worth changing?
a few other bits i want to change while its apart, the cam, are there any specs listed, i presume it'll be a regrind but how far can it been taken to?
also what the usual way for th chips? is it a case of soldering in a cradle with eproms?
once thats out the way i'm hoping to find some bargains for testng with.
just the intercooler tho,
http://cgi.ebay.co.uk/FORD-SIERRA-E...arts_Vehicles_CarParts_SM&hash=item33676cff82
as i think this rad would work better,
http://cgi.ebay.co.uk/SEAT-LEON-1-4...arts_Vehicles_CarParts_SM&hash=item518e918c32
all being well i plan to do a few more bits to save doin things twice but could do with some ideas, i'm lookin into some lag to prolong the gearbox and up the revs so a different brand, but specs look ok,
http://www.xspoweruk.com/t3-t4-t04e-turbo-anti-surge.aspx
not looked into exhausts properly as dont think i'll b runnin loads of boost so should be fine for now, just the elbow change.
i guess bosch 803 injectors because they seem easy enough to get.
is there any similar cars about? its a shame you can't see car/engine pics and speclists on profiles. . or have i missed summit lol
sorry for such a long post but thought i may ask the job lot as hopin to get crackin in the next couple of weeks
