Missing Link
What voltage did you get at the other side of the relay ? If you had lets say 12volts going in and only 10 volts coming out then there is a loss of 2v across the relay contacts. ( A drop of anything above 0.3 volts is bad )
It could be burnt or pitted contacts in the relay, If your confident enough you can bridge out the relay and feed the pump directly, If the pump fires you'll know the relay is at fault.
