Section 17B-28
ANTI-PERCOLATION FUNCTION
The anti-percolation system is controlled by the
injection computer.
The coolant temperature signal used is the one from
the injection system.
After the engine is switched off the system enters
standby mode. If the coolant temperature exceeds the
limit of 102˚C during the 10 minutes after the engine is
switched off, the front fan unit is controlled at slow
speed.
If the coolant temperature falls below 95°C, the front
fan unit relay is cut off. The fan unit cannot be switched
on for more than 10 minutes.
Likewise, if the temperature in the engine
compartment is greater than 70˚C ±10 after stopping
the engine, the rear fans are actuated.
OPERATION OF THE FRONT FAN UNITS
– The fan unit is controlled at slow speed if the coolant
temperature exceeds 99˚C and is switched off when
the temperature falls below 96˚C.
– the fan unit is controlled at high speed if the coolant
temperature exceeds 102˚C and is switched off when
the temperature falls below 99˚C.
OPERATION OF THE TEMPERATURE WARNING
LIGHT
The coolant temperature warning light comes on if the
coolant temperature exceeds 118˚C and goes out
when the temperature falls below 115˚C.
17B-
