I use 3M. They are very good products and colour coded. For example, I use a green cutting pad with the green top polish (fast cut), and then finish off with a yellow pad and yellow top polish (extra fine). Generally achieve some really good results for a numpty.
You can see in the gallery examples of the finish you get with it as its the only polish he really uses. :approve:
I would say once you have polished the car, to protect with a very high quality product. My absolute favourites at the moment are Dodo Juice Supernatural Hybrid (sealant/wax hyrbid) 6 months protection, plus their new Acrylic Spritz spray.
The lake country pads are great.. Hydra Tech are the ones I'm currently using which don't absorb the polish and avoids burnishing. One thing I don't know since I use a Rotary but can you change the plate on a DA ?
If so the spot pads are ideal on the vees complex areas :approve:
Sealing/waxing should always be done by hand!
If you need any tips give us a shout, only 20 min away these days
