I need to take my upper dash out.
It is just a case if removing screws along the top, sides and in the glove box and popping the pillars off?
Does it just slide out once I have found and undone all the screws?
Airbag light is on and the garage said the fault given was for the passenger airbag. The dash was entirely removed for flocking by the previous owner. They suggested it was either not reconnected or it needs replacing.
If it needs replacing is it something I, with no experience, can safely remove and replace?
