whould anyone be intrested in coilovers for the front of our cars? with adjustable hieght and re-bound price is around 170-180ish each, but dont forget new shock and spring. also rear shocks adjustable for rate only about 70ish price depends onhow many we order.
is this going to be a one off, or an on going purchase possibility? i would be interested eventually, but other things need finishing off before i start on suspension. sadly i am not made of money either :dunno: :dunno:
ok guys thats good, i think the best thing to do is if i get a set made up and fitted onthe car to make sure every thing is ok and then i can get them done for everyone else. and yes these are for quadra but rear shock can be done for 2wd too, but may be a bit more because of the spring.
one other thing is that they will need the struts so they can machine off the steering arm and mounting braket at bottom, hence why i need two struts, your ones from car or knackered ones. i think they will still make them after this time but price may be more.
:good2: finaly picked up coilovers and rear shocks from gaz, still waiting for custom rear spring(uprated and lowered). they look pretty good but will let you guys know after i've fitted them.:good2:
Let us know the results of the road test with them, chances are I'll be interested in a front pair and if there is anything available for 2wd rears by that stage those also.
I have a spare 2wd rear shock they can use depends if it gets destroyed or not as it is brand new.
I do have an old one but the bush in the bottom has had it and the spring has cracked not sure if thats any use to them.
Oh, I'm very interested now.. I think my shocks are original from factory ie. 250000 km's.. Time for a change, and roughly £500 seems pretty ok price wise..
Let us now if you're doing a group order on these, with the springs
