itz_baseline
OK I had a coil failure which resulted in the Engine Management Light coming on. Found the problem coil and changed it. Run smooth again now, but the EML is still lit. HELP! Is this normal? Do I have to take it to Renault to get reset? Will it go out after a few runs out - I've tried switching on and off and been for a 5 minute drive and it's still on. Or is it likely that there's some damage somewhere?
What next?
What next?
