In the last year its had Radiator/thermostat/Cambelt/oil pump/water pump/pulley/battery to boot, and cut off switch/ just fitted front disks/DS 1.11 pads/rear hubs/calipers/handbrake cables/ map sensor/throttle censor/ rear seats and belts removed, and carpet fitted. 4point harnesses, with harness bar/Air con pipes/condenser/Acro Exhaust, the usual 630 inj etc. When I purchased, it has major overheating problems, they fitted bonnet vent/removed front grills, but never cured it. A few days after I purchased, by accident, I found the fan was blowing the wrong way.( Taking air from the engine compartment, and trying to blow it back through th rad, and intercooler, instead of taking air from outside, and sucking it through the rads!!. Problem solved!.) Mapped by RST. I have bills /receipts for over £9500. The car is booked in for MOT, mid October, so available sometime after that. BAD Points, small tear in drivers Recaro on bolster/2 wheels could do with refurb. £9250 Photos will not upload, but will keep trying. [email protected]
