rickytang8838
[smilie=yay.gif]
Hello Guys,
Thank you so much for those good suggestions!
For those active vee performace lover; I have my opinions as following:
1. Cheapest way to get 300hp or more; .... by supercharge
2. Weight lowering .... to enhance handling.
For the first topic:
I take supercharge rather than change engine is because mounting is not easy and all engine , gearbox and others cost too much. In my country, change different engine is not allowed but adding supercharge would be easier for not being checked out. So keeping the standard engine and adding a suitable supercharge (small one) and fix a good size pully can boost power to or more than 300hp without changing too many origanal parts. One side of the in air panel could be used for cooling. ECU might not need to be enhanced for oil supply, but oil pressure regulator, may be needed. If still not enought, than extral ECU. The problem, I concerned is the gearbox...... any suggestion?
Also, if not use supercharge, then, I don't know whether we can find any suitable engine internal up-garding parts, like: ......conn, piston, valve guids, spring etc. I think engine polish for in and exit air is needed too.
2. Weight lowering:
I think all we agreed that our vee is too heavy at the back and relatively light at the front, so anything of weight reducing for the back is good! and lowering a few cm for the engine also ok.
What I have done is:
a. Airbags safed almost 10 kg,
b. carbon door panels (two) 10 kg,
c. Hi Fi 6 to 8 kg
d. manual window regulators and mirrors 5 kg
e. engine top cover ( those plastic ) 8 kg
f. budket seats ( 30 to 40 kg )
g. A/C 15 kg;
h. exhaust 10 to 30 kg (steel or titanium)
i. Finally subframe change to titanium 30 kg at back
Those, weight reducing should greatly change the weak of vee handling and enhance good control for such a nice looking car. My target weight reduction : 1050 kg . That is my opinions and wish you guys could give me some more good suggestion see how to futher improve our lovely vee! [smilie=yay.gif]
rickytang8838
Forum User
Real First Name: ricky
Private message
Hello Guys,
2. Weight lowering:
c. Hi Fi 6 to 8 kg
g. A/C 15 kg;
rickytang8838
Forum User
Private message
