Here is a list of parts from my MK2 PH1 track car which I'm breaking,
MK2 Ph1 172 front bumper in black, Has quick release buttons, could do with a re-spray (see photos) £100
MK2 Ph1 172 set of front wings in black, ok condition £100
MK2 Ph1 172 set of side skirts, in black few of the mounting holes have cracked/split. £50
MK2 Ph2 172 rear bumper, in black, cut out for the exhaust, needs a re-spray due to scratches £30
MK2 Ph1 Aluminium bonet, holes cut for aero catches, ok condition, would need respray £100
Full exhaust system, made by John Ashley to suit a Megane 225 conversion in a MK2 Clio shell, made from stainless 2.5" Includes downpipe, mid-pipe and rear box £200
3 remote reservoirs and mounting plate, two are used and one is brand new £25
Mk2 Ph1 stalks, good working order, the airbag wiring part is broken, still self cancels the indicator though. £40
ETB digi dash 2 LITE, Good condition, comes with loom, but would need new sensors and speedo pickup, loom was cut to suit the car. £100
EPAS conversion kit, comes with ecu, wiring loom, controller, column, motor and DCI rack with new inner arms and TRE's, non gen boots £100
Adaptronic 420C ECU, Around 10 years old, its seen better days but still works fine, can supply a small loom with it as they are discontinued? Again would need new sensors £125
Renault pedal box with hydraulic clutch, came off a kangoo but I was told it was the same as the DCI 100? would need accelerator pedal £60
Mk2 ph2 172 front doorcard £50 for the pair
Half rollcage, bought it years ago from a guy called alan? He used to do all the ford rallying stuff and sold these on Ebay, paint is sratched and peeled off from the feet £50
MK2 Ph1 genuine dogbone mount with polybushes £30
Set of Renault Turinis ET38.5 in white, good condition but ideally could you with a refurb, few marks around the wheel bolt bolts, and have been in storage for awhile, tyres are ok but starting to crack on the sidewalls. Has two hankooks and two nankangs fitted £400
Set of recaro seat adapters for mk2 clio models to fit trendline seats. These bolt onto existing renault seat runners, they need a re-paint, and some new decals, they have an extra hole drilled in them for when I had narrow sized fixed bucket seats in the car. £90
More parts to be added soon.
collection only, from Walsall area, West Midlands WS4.
Any questions please ask.
Photos to follow shortly.
Thanks,
Thanks,
