After trips across Europe and problems in MOT time has come to change rear brake calipers because of hand brake inefficiency and master brake cylinder because i have to press the pedal twice to get it working full force from the start. I have Renault 19 16v ph2 with Bosch ABS. I would like to fit bigger brakes for front and rear but keep ABS working. Has anyone done this before and what units you took from other models? Or maybe i just have to buy factory remanufactured units and keep my solution simple? Can anyone give advice on this problem?
