see the wee brake fluid container thingy under the bonnet it sits on a black bracket, can ye seperate them as mine is all flaking an would like to remove and re paint [smilie=thanks.gif]
its a little different on the ph1 but still unbolts easily and the pipes will support the bottle while the bracket is off being painted. (dont drive the car though!)
2 nuts at the rear of the container secure it to the bracket and then a couple of obvious nuts hold the bracket to the bulkhead and one nut on the brake pipe support.
need to do mine....again.
