brake caliper and pad info
Steve-V6-D61
Front brake pads are same as Morgan Aero 8, Noble and TVR Tuscan.
Best prices found for front pads
OMP OT/8104 £55 inc post road and sport compound on Flea Bay
redstuff DP 3036C for Seat and Clio @ £82.55 + £5 post also on Flea Bay
You will see retaining pin part numbers below as well, this is all off the internet so you NEED TO CHECK THIS INFO FOR YOURSELVES
Tightening torques for calipers
Bleed screw : 17Nm
Hydraulic feed : 25Nm
Retainer bolts : 17Nm
Caliper to upright bolts : 120Nm
Look up CP6600 calipers on the AP website for loads more info on parts and pads.
Performance Road Front.
- Formula Brake Kits.
Features:
- Radial Mount, 130mm centres.
- Suits Ø330 x 30mm thick disc.
- Cast two piece Aluminium alloy body.
- Aluminium alloy pistons.
- Boot type dirt seals fitted.
- Advanced Red or Black anti-corrosion paint finish.
- Steel wear plates.
- Pad anti-rattle clip fitted.
Black Caliper Part Numbers:
Right hand trailing - RHT = CP6600-6S0 / - LHT = CP6600-7S0.
Right hand leading RHL CP6600-8S0 / - LHL = CP6600-9S0.
Red Caliper Part Numbers:
For Red calipers add 'R2' to end of Part Number e.g.
CP6600-6S0R2
Downloads CP6600 Installation Drawing
Brake Pad Information
(To view larger image of pad
click on Pad Part No) CP6600D55
Pad Area = 64.6cm³
Pad Depth - 55.0mm
Thickness = 16.8mm
TECHNICAL SPECIFICATIONS
Piston Sizes - mm - Ø38.1 x 2
- Ø41.3 x 2
Disc Diameter - mm Ø330.0
Disc Thickness - mm 30.0
Weight (no pads) - Kg 2.8
Hydraulic Threads M10x1.0
Mounting Type Radial
Mounting Centres - mm 130.0
Mounting Offset - mm 54.0
Mounting Hole Ø - mm 10.1
‘PL’ Dimension - mm 64.5
Bleed Screw Tightening Torque 17Nm
SPARE PARTS
Pistons - Ø38.1 = CP6200-104
- Ø41.3 = CP6200-105
Seal Repair Kit CP4525-JK
Anti-knockback Springs N/A
Pad Retainer Type / Part No Pin / CP6600-109 x 2
Pad Retainer Bolt Part No N/A
Wear Plates CP6200-103 x 4
Bleed Screw CP3880-1
Fluid Pipes CP6600-10
