BMC-What should I be paying
And for the record its a possible home install job. Lots of torx screws and a few bolts and hose clips.
Took me a while tho. :roll:
Peter :D
Cheers
Well Ill be fitting my quicksilver exhaust as well, it could be an interesting day, sore knuckle and a sudden hatrid towards the V6
You'll have the cover off for the BMC so you might as well fit the exhaust at the same time!
I meant you're better off with the top covers removed to get access to the exhaust, surely? Or do you just have to remove the undertray to fit the backbox?
backbox just comes out with a bit of fiddling with the rubber mounts (grrr) but nothing needs removing, just jack the rear of the car up!
remember that when you jack up the rear you MUST put axle stands under the car. A great friend of mine was killed when the jack slipped and the car crushed him.
