Big rear brakes fitted
James my good man they are 4pot front callipers and discs also Scott had some discs drilled and grooved for the front[album]11863[/album]
[album]11864[/album]
Fastevo1":bufmgmxb said:
Can't see the point in this unless it's for cosmetic reasons? If that's the case fair enough.
Simon's car is quintessentially over-engineered. The Vee has it's inherent flaws and some of us like to tinker.
You've much to learn young padawan...
Looks great. Will you be adjusting brake pressure bias forward to compensate for larger disc radius/larger pads/larger piston areas blah blah?
I don't need to lean thanks, I know enough ;-)
Nothing wrong with the standard setup if used with decent pads and fluid.
Hence why I asked if it was cosmetic.
What do the cup cars run out of interest?
bill patchall":lf49flz6 said:
Hi keir we are looking in to it now
If you're still tinkering, a few Citroen models (xantia etc) had the handbrake operating on the front calipers...probably worth looking at if you haven't already considered it
Looking good!
I have always wondered about having 4 pots at the rear as well as at the front. All cars (that I've seen) that do not have 50:50 weight distribution tend to have bigger brakes up front than at the rear. i.e., a Porsche 911 can have 6 pot up front and 4 pot at the rear. However a Porsche 944 S2 (which has 50:50 weight distribution) has 4 pots all round.
Is this on-purpose? i.e., if you are to upgrade the rear brakes to 4 pots, is it wise to upgrade the fronts to bigger ones too?
