Any good?
James, your car is probably remapped for 98ron fuel already and as such would benefit more than a car with a standard map.
Spoken to Andy and he confirms its has indeed. Even suggested this stuff might be good for it now and then.
Be carefull with this stuff. They say (Millers) that it raises the octane level by 2 points for 1 bottle. 2 points is 0.2 RON, so you would need 5 bottles to raise say a full tank from 97 to 98.
Waste of time and too costly.
If you want to raise octane levels, use industrial Toluene and add this to your fuel.
As said before, unless you have a mappable ECU to take advantage, then its useless, since the the higher the octane level (RON), the more the fuel has the ability to delay detonation, but a standard ECU cannot take advantage of this.
Just use Tesco 99 or v-power 99 fuel, 100 RON is really only for Jap import cars.
Nik
