Neal R19
The 21 splits the oil pressure sensors in to two separate items, not sure if the 19 does that or is a combi sensor? There's a switch and a mushroom pressure sender which is similar to whats used on the 5/9/11/etc
Yeah, 2 sensors on the 19, mushroom one with a single spade terminal for operating the pressure gauge when it's running, and a separate switch next to the filter just for the low pressure light I think.
There's probably not a single one still working on 19s that hasn't been replaced at this point. Chris Hall cuts them open and repairs them.
I think on the 19s there were 2 types - a white one on early cars and then a black one (modified design maybe) later on. Anyway, both types are crap and NLA I believe.
FAE 14970 looks like it might work as a replacement and the part number cross references to the 21T sensor Renault part number but they are quite expensive and I don't want to spend out without confidence that it works on a 19.
