Air-Con
Milky
Just re-gassed my air con as hasn't been used for over a year (prefer the windows down to hear the noise) couldn't find the weight needed to refill so guest at 650g and this leads to my first question
Does anyone know what the correct weight of the gas should be?
Second question- when I started the car to test the air con only the o/s side pod kicked in, the rad fans did not come on is this correct on a ph1 or should the front fans kick in also?
Third question- does anyone know what the low and high pressures should be? my low is 6psi and high is 18psi which seem extreamly high to me.
Cheers
Some of your answers here
Quite a lot of Air Con info in the fault finding section 62. Might be useful if you understand this sort of technical stuff. LINK
