ABS
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    abs
G
Guest
The abs light has been on on my clio since i bought it 4 months ago or so, how do i fix it so the abs actually works?
Take it to a garage that have a diagnostic computer, plug it in and see what it says the problem is!!
That would be the easiest thing to do other wise there are loads of things to check manually :?
Probably the unit itself or a sensor at the wheel knackered (not sure where it would be exactly)
