a few more...
Mechanical characteristics: Engine - Clutch - Transmission
Symbol vehicle 822000
Engine Type 840-30
Displacement 1397 cm3
Bore 76 mm
Stroke 77 mm
Compression ratio 7:1
Maximum power 160 hp DIN at 6000 rev / min
Maximum torque 22.1 kgm or 22.5 daN.m DIN at 3250 rev / min
Settings
Rocker bolt torque 7 mkg
Clearance of hot and cold rocker
* Intake 0.30 mm
* Exhaust 0.40 mm
Valve gear:
* intake opening 28 deg BTDC
* intake closing 52 deg ABDC
* exhaust opening 66 deg BBDC
* exhaust opening 14 deg ATDC
Firing order 1-3-4-2
Ignition: electronic
* transistorized ignition without points
* Spark plugs: CHAMPION BN 2
* ignition point: 10 deg to less than 1000 rev / min.
* spark plug electrode spacing of 0.65 mm to 0.55
Power: mechanical injection and turbo-compressor
* idle speed: 1050 +/- 50 r / min
* Co 1 to 1.5%
Compressed air cooled heat exchanger.
Engine coolant:
Frost protection -23 deg C
Oil Cooler
Clutch: bi-disc hydraulically actuated, powered by the brake fluid reservoir.
Thrust ball bearing.
Gearbox
369 Type: 5-speed + reverse
Gear ratio
1st 3363:1
2nd 2.058:1
3rd 1.38:1
4th 1.057:1
5th 0.886:1
Reverse 3.189:1
Final drive 3.888:1
Chassis Features
Weight
Empty (kerb weight):
* Front 360 kg
* Rear 540 kg
* Total 900 kg
Maximum permitted axle weight
* Front 550 kg
* Rear 690 kg
Maximum loaded weight allowed 1240 kg
Steering
Steering rack gearing: 17/1
Turning radius:
* 10.4 m between curbs
* walls between 10.9 m
Wheels
* Front: width 135 / 340 mm diameter
* Rear: width 195 / 365 mm diameter
Tyres:
Front 190/55 VR 340
Rear 220/55 VR 365
Axles and suspension
Front axle:
* camber angle of 0 to 30 deg
* castor angle 13 deg
* KPI/steering axis inclination (equal 2 sides) Max difference 1 deg
* toe-in: 1.5 to 2.5 mm
(height of the lower spar below 120 mm to that of the axis of the wheels).
Rear axle
* camber angle: -2 deg 25 mins +/- 15 mins
* Toe-in: 2 to 3 mm
Front suspension:
* Independent wheels.
* Longitudinal torsion bars.
* Anti-roll bar.
* Telescopic hydraulic dampers on the lower arms.
Rear Suspension:
* Coil springs.
* Telescopic hydraulic dampers on the upper arm.
* Anti-roll bar.
Braking
* front and rear disc brakes
Minimum lining thickness
* Front: 7 mm
* rear: 7mm
Foot Brake:
Hydraulic four-wheel, dual circuit brake distribution and brake servo-assisted vacuum.
Handbrake: mechanical control acting on a bracket on each rear wheel.
Identification
The identification plates are in the engine compartment.
A - Oval plate
1 Symbol of vehicle
2 Vehicle Features
3 Equipment number
4 Options
5 Serial number
6 Vintage model year (for some countries)
B - Nameplate
7 Type of vehicle
8 Number in the type series
9 Maxium loaded weight
10 Gross Rolling Weight - vehicle laden with trailer
11 Max loaded weight front axle
12 Max loaded weight rear axle
13 Year of the current model (for some countries)
C - Engine plate
14 Engine model
15 engine Index
16 Engine number
Spare parts
This vehicle is confirmed by all the regulations in force in the country where it is sold. Any modification, addition or replacement of original parts or Reanult Alpine Renault, by parts of another origin, carries the risk that the vehicle will not comply with safety regulations/anti-pollution/noise/Highway Code, and exposes the owner of this vehicle as amended, for the eventual criminal proceedings.
Furthermore the manufacturer's warranty is refused when parts were incorporated or changes to the vehicle, as they are not authorized or provided by the manufacturer.
All parts of your car have been studied and designed with same quality, to ensure your safety and give you any satisfaction.
Whether all the parts constituting:
-the braking system
-lighting
-signaling
-exhaust system
-steering control
-engine
-engine equipment
-body, mechanisms, wheels and tyres,
-or all exterior and interior fixtures.
The mention of 'genuine parts' on any repair bill is a compliance assurance.
