Turbell
Yep, but I bilt into anywhere that I'll not be able to get to before I weld, then bilt it all after, new and old, give new a crosshatch with 80 grit, it etches in nice.Remind me the sequence of events:
Find rust
Clean/cut out rust
Weld
Bilt Hamber (Do you put this on new metal or only cleaned up old metal?)
Prime
Paint
That right?
My mate did a full 1948 shell in bilt, after sanding it back to metal, because of pitting, and he works in bodyshop training, still perfect nearly ten years on.
Primer is you're choice, if it's gonna be finished, then I'd rattle etch it to be double safe then prime and final finish, if it's gonna have seam sealer and gravitex, then i brush Zinc 182 on first.
Make sure it all gets cavity waxed.
I use what I trust, and my old man paints a bit of whatever we discover, or get recommended onto a clean test piece and a rusty test piece, and sticks them out in the elements.
He's done it for years, then we can see what holds out and what doesn't........why the winter evenings fly by.
